CW Noise upon switching from transmit to receive
Hi,
My setup is a 6600M + PGXL into a vertical antenna. I run CW mostly with BW set to about 150Hz, AGC set to medium and RF gain set to 0dB. I adjust the agc to just start squelching background noise. Only one slice is operating.
Recently, in contests on 20m I have been experiencing a loud blast of noise that starts when the radio switches from transmit to receive and fades away after 1-2 seconds. The noise sounds exactly like a nearby powerful station overloading the receiver, except it occurs with no stations closer than about 3-5 KHz.
After the 1-2 second recovery period the noise is gone and the receiver performs normally even though the loud nearby stations are still transmitting.
I am not sure but the noise does not seem to appear on the waterfall under my receiving frequency so, it is not a spurious signal generated by some other station. I think it is generated inside the receiver.
It is not intermittent, it occurs on every transmit-to-receive transition but, does not occur when no other stations are on the band.
Is there some setup that I can change to eliminate this problem?
Regards,
Jim Charlton AD0AB
Did you set TX delay to 10-20 ms?
Radio Tab - TX - TX Delay
Bill
W9JJB
Hi Bill,
Yes, the TX Delay is set for 25.
It really seems like as soon as the radio switches to receive, the front end is momentarily overloaded and some sort of internal agc reduces the gain over a period of 1-2 seconds. After that brief recovery period, the noise is gone and the receiver rejects adjacent signals, even really strong ones.
Regards,
James Charlton
I can remember something like you are hearing. Just for grins set your CW filter to "LOW LATENCY" and turn off "AUTO". I have no idea if that will work, it solved my problem.
Gayle K0FLY
Gayle,
Thanks, I'll try that.
Regards,
Jim AD0AB
Gayle,
Sorry to take so long to reply, but your fix seems to have worked. I just finished a CWops sprint with a lot of closely spaced sprong signals and not a sign of the noise.
Thanks for the advice,
Jim AD0AB
Glad it worked for you. Thanks for the feed back
Gayle K0FLY
- 335 Community Topics
- 602 The Flea Market
- 7.9K Software
- 6.2K SmartSDR for Windows
- 400 SmartSDR for Mac
- 263 SmartSDR for iOS
- 247 SmartSDR CAT
- 184 DAX
- 371 SmartSDR API
- 9.1K Radios and Accessories
- 17 Aurora
- 179 FLEX-8000 Signature Series
- 913 Maestro
- 882 Genius Products
- 319 Tuner Genius XL
- 116 Antenna Genius
- 280 Shack Infrastructure
- 196 Networking
- 137 Contesting
- 736 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 950 Third-Party Software
