FLEX6600M cannot be turned on, the red light flashes
bd7jmr
Member ✭
The FLEX6600M cannot be turned on, the red light flashes alternately and cannot be turned on, how can I check it!
It happened to me too, flashing red three times (letter O). It appears to be the internal SD card. It is a (very simple) repair that the technician must do if it is still under warranty. Contact support / seller.
Or see here, there are some cases: https://www.google.com/search?q=flexradio+red+light&oq=flexradio+red+light&aqs=chrome..69i57j69i64j69i60.11423j0j9&sourceid=chrome&ie=UTF-8
Thank you for your reply, the dealer has been contacted and the SD card needs to be updated .
BD7JMR 730 -
can the user upgrade the SD card?0
The user can replace the card with one sent by Flex. I wouldn't assume that you have a bad card. Submit a help desk ticket and Flex will determine if it makes sense to replace the card or not.
- 379 Community Topics
- 636 The Flea Market
- 140 SmartSDR+
- 260 SmartSDR CAT
- 199 DAX
- 44 Aurora
- 271 FLEX-8000 Signature Series
- 956 Maestro
- 57 FlexControl
- 301 Shack Infrastructure
