Store the 6400 on it's side?
rbenton01
My desk is equipped with a CPU vertical storage space, not wide enough to set up the 6400 horizontally on it's feet. Is it advisable to set it up to rest on its side?
I have my 6600 on its side without a problem. There are ventilation holes on the side of the cabinet (which will end up on the bottom). Make sure there is clearance for air flow to them.
73, Pat KØPC
As long as you have a 1" clearance for the air intake vents on the side that is facing downward, you should be OK.
- 690 The Flea Market
- 197 SmartSDR+
- 112 Aurora
- 322 Shack Infrastructure
- 227 Networking
- 146 Contesting
