I need help connecting a Heil HM-10 Duo to my 6600. 4pin xlr on mike.
KE4DZU
what are the pin connections and cable type to hook up an HM-10 Dual element to my 6600, the mike connecter is a 4pin XLR.
Is this what you're looking for? The radio end connections are in the manual.
I also found this for the cable from Markertek.
[{"insert":"Thanks, this gives me the info to make a cable. 😁👍\n"}]0
[{"insert":"\n"}]0
this should be the same wiring as the Heil Gold Line the 4th wire is for the PTT button on the MIC.
Should be a easy MIC side cable to find through Heil or maybe FLEX, you may have to rewire the radio end with a 1/4" TRS (like the old fashioned 1/4" Headphone jack) and a RCA jack for the PTT split off the cable.
I always build my own custom cables and have found the 4-pin XLR on Ebay
here is the connector's on EBAY
- 389 Community Topics
- 53 Aurora
- 971 Maestro
- 945 Genius Products
- 307 Shack Infrastructure
