FT8 On IPAD Pro
Jeff
FT8 decoding but not transmitting correctly. It appears that the transmit audio drops 10 to 15 seconds before the push to talk unkeys when running SmartSDR for IOS on my IPad Pro.
I am using a Flex 6600. Software on Flex 6600 is latest version 3. Ssdr for iOS is latest version.
I have the same results using WiFi or cellular connection.
Sometimes a station will connect to me but then connection times out after 6 tries by my transmitter due to too many attempts.
Any ideas how to fix?
Jeff
KD6RC
Jeff
KD6RC
Jeff,
I have similar problem where the transmitted audio breaks up. Should I connect with another station, we never complete the contact due to many re-tries. Also I get about half the number of decodes compared to when I use SmartSDR and WSJTX on the computer.
Did you find an answer to your problem?
Brian, W9HLQ
- 391 Community Topics
- 664 The Flea Market
- 441 SmartSDR for Mac
- 206 DAX
- 60 Aurora
- 974 Maestro
- 948 Genius Products
- 348 Tuner Genius XL
- 127 Antenna Genius
- 308 Shack Infrastructure
- 216 Networking
