WSJT Tracking flex Freq.
DonE
Is WJST suppose to track the flex Freq? Mine does sometimes and sometimes it does not > Am i missing a setting?
WSJT-X will track the Flex frequency if set up correctly. You can create a TCP CAT port 5004 and then in WSJT-X setup under radio select Flex 6xxx. For the IP address use 127.0.0.1:5004
If you would like help I can assist via TeamViewer. Email me direct at
my call AT arrl DOT net
Dave is correct. Here is a You Tube link showing step by step setup for Smart SDR and WSJT-x.
https://www.youtube.com/watch?v=vxageEY7-Pw
Gayle K0FLY
Thanks fellows working much better, thanks for your help
- 650 The Flea Market
- 152 SmartSDR+
- 49 Aurora
- 964 Maestro
- 937 Genius Products
- 343 Tuner Genius XL
