Flex 6400 stopped keying amplifier
Flex 6400, running 2.6.2 or 3.1.12, stopped keying ampfifier. If I short the tx cable that connects to the Flex, it does turn on the amplifier tx light and responds to rf input from the Flex.. Tried my Flex 6300, also no keying. Same result with either Expert 1.3K-FA or Ameritron AL-80B, so that seems to rule out the amp as the problem.
I had been operating in the 160 CW contest using Expert amp and N1MM+ with no problems. Took a 2 hour break with the amp in standby. When I returned N1MM+ was not working. Found that the CAT had lost all but 2 of the defined com ports. Created new com ports and got N1MM+ working again. No idea what caused the CAT problem. As part of the troubleshooting I did reset the 6400 to factory defaults. Also, the 6300 had been reset due to an intermittent problem.
So, is there some configuration setting in SDR that controls when the TX port on the Flex works?
Solved. When my computer "burped" it resorted to default profile. Dor some reason this does not work. Switched to SO2RDefault and it works.
- 398 Community Topics
- 678 The Flea Market
- 191 SmartSDR+
- 392 SmartSDR API
- 91 Aurora
- 988 Maestro
- 962 Genius Products
- 352 Tuner Genius XL
- 317 Shack Infrastructure
- 222 Networking
