change mode between cw - usb/lsb
Hello everyone
i ran this problem on my 6400 with ssdr. if I was operating in a band for example 15 meters cw mode when I return to the band I had left 40 meters lsb this freq. is set in cw mode. this happens with all freqs. the band left in usb / lsb mode is set to cw mode when I return. I hope I was clear
This is a guess, but it may be a persistence database issue. There are discussions here, and there is a document on the flex site.
could you give me the link
Google is your friend. A search for flex radio persistence database brings the document up as the first item.
tnx
Profiles are your friend, if you create global profiles for your differant operating bands/modes you will accomplish what you want and your layout will always be how you left it, I haven't touched the band buttons in years .
True too. Also the memories and hot keys in the free frstack program add a lot of convenience and consistency to flex operation.
Yes, all you can do, but it's not normal anyway.
Tnx again
- 318 Community Topics
- 575 The Flea Market
- 7.7K Software
- 6.1K SmartSDR for Windows
- 157 SmartSDR for Maestro and M models
- 386 SmartSDR for Mac
- 251 SmartSDR for iOS
- 244 SmartSDR CAT
- 177 DAX
- 356 SmartSDR API
- 9K Radios and Accessories
- 125 FLEX-8000 Signature Series
- 891 Maestro
- 50 FlexControl
- 848 Genius Products
- 437 Power Genius XL Amplifier
- 298 Tuner Genius XL
- 103 Antenna Genius
- 268 Shack Infrastructure
- 189 Networking
- 132 Contesting
- 699 Peripherals & Station Integration
- 131 Amateur Radio Interests
- 923 Third-Party Software
