change mode between cw - usb/lsb
Hello everyone
i ran this problem on my 6400 with ssdr. if I was operating in a band for example 15 meters cw mode when I return to the band I had left 40 meters lsb this freq. is set in cw mode. this happens with all freqs. the band left in usb / lsb mode is set to cw mode when I return. I hope I was clear
This is a guess, but it may be a persistence database issue. There are discussions here, and there is a document on the flex site.
could you give me the link
Google is your friend. A search for flex radio persistence database brings the document up as the first item.
tnx
Profiles are your friend, if you create global profiles for your differant operating bands/modes you will accomplish what you want and your layout will always be how you left it, I haven't touched the band buttons in years .
True too. Also the memories and hot keys in the free frstack program add a lot of convenience and consistency to flex operation.
Yes, all you can do, but it's not normal anyway.
Tnx again
- 383 Community Topics
- 640 The Flea Market
- 147 SmartSDR+
- 435 SmartSDR for Mac
- 262 SmartSDR CAT
- 201 DAX
- 280 FLEX-8000 Signature Series
- 958 Maestro
- 934 Genius Products
- 342 Tuner Genius XL
- 305 Shack Infrastructure
- 214 Networking
- 142 Amateur Radio Interests
