change mode between cw - usb/lsb
Hello everyone
i ran this problem on my 6400 with ssdr. if I was operating in a band for example 15 meters cw mode when I return to the band I had left 40 meters lsb this freq. is set in cw mode. this happens with all freqs. the band left in usb / lsb mode is set to cw mode when I return. I hope I was clear
Welcome!
  • Member ✭✭✭✭
    This is a guess, but it may be a persistence database issue. There are discussions here, and there is a document on the flex site.
  • Member ✭✭
    could you give me the link
  • Member ✭✭✭✭
    Google is your friend. A search for flex radio persistence database brings the document up as the first item.
  • Member ✭✭
    tnx
  • Member ✭✭✭
    Profiles are your friend, if you create global profiles for your differant operating bands/modes you will accomplish what you want and your layout will always be how you left it, I haven't touched the band buttons in years .
  • Member ✭✭✭✭
    True too. Also the memories and hot keys in the free frstack program add a lot of convenience and consistency to flex operation.
  • Member ✭✭
    Yes, all you can do, but it's not normal anyway.
    Tnx again
