DAX only works on CW
Sounds like there are two problems.
1) You're looking to DAX RESERVED - use the non-reserved port. Reserved is for internal use in DAX. Unfortunately, Windows doesn't know any better.
2) Are you using The I/Q setting (left menu) or the DAX setting from the main menu (and flag)? The proper DAX dialog is the audio (not I/Q) one.
Hope this helps!
George
TU for comments. Turned off W10 PC and 6600 for the night rebooted and it worked for 2 hours! Now suddenly cant get any output from 6600
all transmit lights go on no output any mode-grrrrrrrr!
73 Roger N3RC
Hi Roger, Have you checked that the RF Power control did not get set to zero? Also check in Settings, TX Band Settings that PTT Inhibit is not checked and that the RF PWR column is where it should be for the band in question. If you are using the mic to transmit (i.e. not a digital mode), you should be sure that in the P/CW tab of the radio panel, DAX is not highlighted and that MIC is selected. Also be sure that the mic cable did not come loose from the back of the radio. PTT will operate with no mic because it is on a separate jack, so this is something to check.
Len, KD0RC
- 369 Community Topics
- 628 The Flea Market
- 85 SmartSDR+
- 422 SmartSDR for Mac
- 270 SmartSDR for iOS
- 35 Aurora
- 243 FLEX-8000 Signature Series
- 937 Maestro
- 54 FlexControl
- 916 Genius Products
- 333 Tuner Genius XL
- 451 Remote Operation (SmartLink)
- 780 Peripherals & Station Integration
- 996 Third-Party Software
