change mode between cw - usb/lsb
Hello everyone
i ran this problem on my 6400 with ssdr. if I was operating in a band for example 15 meters cw mode when I return to the band I had left 40 meters lsb this freq. is set in cw mode. this happens with all freqs. the band left in usb / lsb mode is set to cw mode when I return. I hope I was clear
This is a guess, but it may be a persistence database issue. There are discussions here, and there is a document on the flex site.
could you give me the link
Google is your friend. A search for flex radio persistence database brings the document up as the first item.
tnx
Profiles are your friend, if you create global profiles for your differant operating bands/modes you will accomplish what you want and your layout will always be how you left it, I haven't touched the band buttons in years .
True too. Also the memories and hot keys in the free frstack program add a lot of convenience and consistency to flex operation.
Yes, all you can do, but it's not normal anyway.
Tnx again
- 632 The Flea Market
- 127 SmartSDR+
- 195 DAX
- 40 Aurora
- 955 Maestro
- 927 Genius Products
- 338 Tuner Genius XL
