Flex 6600M keying Henry 3K Premier amplifier.
Simple question, how do I key the Henry amplifier safely? The amplifier keys by a ground closure. It has +26 volts on the key line.
Steve KD2OM
Good luck on this one.. As I remember from some years ago, the Henry used a large open pole relay with no suppressor diode across the coil thus one heavy back surge when keying.. My best to your radio keying circuit.. Jim K4JAF
Hi Steve,
I have keyed a Henry 2K and a SB200 amp with my 5000 and 6600. I built a little circuit in a small box to go between the Flex and the amp. It was just a junkbox 12V relay and a couple other parts. The relay contacts connect to the amp. I believe I used a couple of transistors and a couple resistors. Probably an easier way but I used what I had.
A friend keys his older amp with one of these: https://www.dxengineering.com/parts/ame-arb-704
Hope this helps!
73, Mark K5XH
Thanks Mark,
I found a solution that I already had but forgot about. I have a Denkovi USB relay board that the 6600M recognizes. I just configured one of the relays to key the amplifier.
I looked into the ARB-704, that probably would have been the next step.
Steve KD2OM
Harbach Electronics sells a small Keying Interface circuit board that protects sensitive HF radios from
high-voltage Keying energy in older Heathkit amplifiers.
https://harbachelectronics.com/0
- 650 The Flea Market
- 151 SmartSDR+
- 263 SmartSDR CAT
- 48 Aurora
- 964 Maestro
- 936 Genius Products
- 343 Tuner Genius XL
