FRStack dotnet install failed
Hi,
I have a new Pi that I am trying to load dot net on and I am getting the following error when I this execute this command :pi@svarcPi:~/Downloads $ sudo tar -zxf aspnetcore-runtime-3.1.7-linux-arm.tar.gz -C /opt/dotnet
tar (child): aspnetcore-runtime-3.1.7-linux-arm.tar.gz: Cannot open: No such file or directory
tar (child): Error is not recoverable: exiting now
tar: Child returned status 2
tar: Error is not recoverable: exiting now
I did some research and thought the issue was that I was running an ARM 7 processor so I loaded version 5.0.x ...
When I try to run dot net I get this error:
pi@svarcPi:/usr/local/frstack $ dotnet FRStackWebApi.dll --urls "http://*:5025"
It was not possible to find any compatible framework version
The framework 'Microsoft.AspNetCore.App', version '3.1.0' was not found.
- The following frameworks were found:
5.0.0-rc.2.20474.4 at [/usr/share/dotnet/shared/Microsoft.AspNetCore.App]
You can resolve the problem by installing the specified framework and/or SDK.
The specified framework can be found at:
I am hoping Mark will see this and advise on how to proceed. I do have the luxury of blowing out the OS and reloading. Not sure if it matter but I am running a 64Gig SD card.
Mick
Mick
I checked the MS Dot.net web site. Looks like they are using version 3.1.8 now.
//so, use to download to the downloads directory
cd ~/Downloads/
//then, to unzip into the /opt/dotnet directory and add a soft link to the /usr/bin directory :
sudo mkdir -p /opt/dotnet
sudo tar -zxf aspnetcore-runtime-3.1.8-linux-arm.tar.gz -C /opt/dotnet
sudo ln -s /opt/dotnet/dotnet /usr/bin
Alan
Mick
I used the incorrect tar command. I corrected my previous post. It now has the correct commands.
Alan
It is the tar cmd that is barfing...i am thinking th 64g sd card is the issue...i will get a 32g and try..
Thx
Mick
Try again. Others have used a 64 g card
i omitted the “t” in “dot net” mkdir command
👋 Alan, u da Man...
It went like clockwork this time...
Mick
I did some updates to the UI and I think this may be what the prod env will look like..(for today)..
- 375 Community Topics
- 104 SmartSDR+
- 425 SmartSDR for Mac
- 999 Third-Party Software
