Trying to have independent antennas in slices
np4zulu
np4zulu Member ✭✭
Guys, Im a new user, so far so good..6600, pgxl maestro , dxlog , antenna switrching..everything is working as advertised. But I'm trying to select independent antennas on each slice for example slice A ant1/ant1 Slice b Ant2/ant2 . I doesn't matter what I try, one of the slices changes the ant to be the original. for example.
14.000 ant1/ant1 3,500 ant1/ant2
Looks like there's a control somewhere not allowing me to do it.
Any idea?
felipe
NP4z
  • Felipe, you need to open a separate panadapter for Slice B in order to use a different antenna for receive than Slice A. It’s explained in detail here:
    https://community.flexradio.com/discussion/comment/20579008#Comment_20579008
    Howard
  • np4zulu
    np4zulu Member ✭✭
    > Howard
    it was related to the so2r profile. It wasn't acting normal, factory defaulted it and now is ok.
    Felipe
