PTT Com Ports not working
Dan KG0AQ
6400 running 2.6.2
- I checked for ghosted com ports...none
- I checked for duplicate com ports...none
- Deleted then added com port in CAT...no go
- Rebooted everything...no go
- I used Com Arbiter...looks good
Running out of ideas? TIA!
Dan KG0AQ
@Dan KG0AQ Make sure you DTR and RTS configured properly.
Forgot to put that on my list Tim. No issues there either.
I looked again at all this. Ports are clean as can be everywhere. No ghosts, hidden or pre halloween horror. I ran the repair on the FlexVSPInstaller with no joy. I have no automatic PTT with KD9R Voice keyer or the ****. Audio triggers fine. Is it time for help desk ticket?
**** is the software program for tuning tube amps. Hi
- 379 Community Topics
- 634 The Flea Market
- 139 SmartSDR+
- 260 SmartSDR CAT
- 199 DAX
- 44 Aurora
- 270 FLEX-8000 Signature Series
- 956 Maestro
- 57 FlexControl
- 301 Shack Infrastructure
