PTT Com Ports not working
Dan KG0AQ
Dan KG0AQ Member ✭✭
edited September 2020 in SmartSDR CAT
6400 running 2.6.2
  1. I checked for ghosted com ports...none
  2. I checked for duplicate com ports...none
  3. Deleted then added com port in CAT...no go
  4. Rebooted everything...no go
  5. I used Com Arbiter...looks good
Running out of ideas? TIA!
Dan KG0AQ
  • Tim - W4TME
    @Dan KG0AQ Make sure you DTR and RTS configured properly.
  • Dan KG0AQ
    Dan KG0AQ Member ✭✭
    Forgot to put that on my list Tim. No issues there either.
  • Dan KG0AQ
    Dan KG0AQ Member ✭✭
    I looked again at all this. Ports are clean as can be everywhere. No ghosts, hidden or pre halloween horror. I ran the repair on the FlexVSPInstaller with no joy. I have no automatic PTT with KD9R Voice keyer or the ****. Audio triggers fine. Is it time for help desk ticket?
  • Dan KG0AQ
    Dan KG0AQ Member ✭✭
    **** is the software program for tuning tube amps. Hi
