Magnetic Loop Antenna Choices for Flex Radio
Avan
Member ✭
:) I want to buy Flex Radio 6700. One thing I wanted to check if I can operate Flex Radio with Bushcomm 40 Magnetic loop antenna. I live in a big city and I have a patio space in a high rise condos with multiple stories. If a magnetic loop is not sufficient, would you recommend an alternative antenna? And do I need SWR/external Antenna tuner with Flex radio 6700 (in addition to their ATU)?
Avan, I have lived in a big city and high rise condos for over 12 years. All attempts at small, local antennas were not satisfactory, due to low heights, blocked by building(s) in several directions, and the high RF noise levels from surrounding buildings. I installed a remote station with a Flex, and I use RemoteHamRadio.com which uses Flex radios. Mark K6UFO
Avan,
The mag loop is not much different with Flex Radio than any other radio.
I have used it effectively from a downtown condo balcony in Denver CO.
A couple of things-
From this balcony there was a clear shot to anywhere except "through the building" which was to South America. The balcony was up 185 feet, the mag loop horizontal was a real performer at that height.
If you are using it with a 6700, be aware that with the narrow tuning of the mag loop you will only have one slice open at a time. Forget about multiple slices, multiple bands. The mag loop is just two narrow. Whenever you QSY, you have to retune the mag loop.
As above, personally I prefer to remote my 6500. Remoting is very native to SmartLink.
Dave KØKQ2 -
:) :) Thank you K6UFO and K0KQ.0
- 394 Community Topics
- 670 The Flea Market
- 176 SmartSDR+
- 453 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 80 Aurora
- 321 FLEX-8000 Signature Series
- 982 Maestro
- 954 Genius Products
- 350 Tuner Genius XL
- 130 Antenna Genius
- 312 Shack Infrastructure
- 218 Networking
- 146 Amateur Radio Interests
