What power supply do you recommend for SO2R operations
I have participated in the WW DIGI contest last weekend. That was my first SO2R operations ever. I was using a Flex 6600. Evertthing went well but, at the end of the contest, my power supply decided to show some disagrements after a day of near continus tramsmission.
So here is my question to experienced Flex SO2R operators. What kind of power supply do you use or recommant for your radio.
Best Answers
  • Joe N3HEE
    Joe N3HEE Member ✭✭
    What do you mean by disagreements ? The RS-35 should be fine for what you are doing. I use the Astron RS-50M. More than enough current to run multiple radios and accessories. It also runs a little cooler during long contests. I never pay attention to the meters. You can save some $$ and go with RS-50A.
  • Martin Bérubé
    Martin Bérubé Member ✭✭
    edited September 2020
    Joe,
    This mean a capacitor blew up. Is is a RS-32A
    Thank you for your comment.
  • Joe N3HEE
    Joe N3HEE Member ✭✭
    Who is the manufacturer of that power supply ? Astron makes very good highly reliable power supplies.
  • It's an Astron RS-35A
  • EBSDallas
    EBSDallas Member ✭✭
    I use a pair of RS-35A’s. One powers only the radio (6600). The other runs various shack accessories (HF-Auto, antenna switch etc.). I have had both for years and have not had a problem with either of them except for the incandescent meter lights burning out (replaced with blue leds). While I often run digital modes, I do not do any digital contesting. I do run a little casual cw contesting and a lot of serious phone contesting and they have kept up without issue. Does yours run more than just the rig? It’s always possible yours had/has a marginal component in it that isn’t up to the stress imposed by extended digital contesting. It might be worth a call to Astron. I’ve always found them to be very helpful and pleasant to deal with.
  • Stan VA7NF
    Stan VA7NF Member ✭✭✭
    The best configuration is a 10-100 Ah battery with marine circuit breaker (low resistance, no fuse contacts to film over) that is charged by any of the suggested power supplies through an appropriate charger - I am not recommending any specific hardware as it will change with the battery type chosen. Note: Many Li-ion batteries have enclosed charge controllers so they can be charged directly from the PS.
    The advantages are:
    + Pure DC with most PS birdies filtered out and a .01 uf mica for HF+ and .1uf capacitor for audio in parallel across the battery helps even more
    + Several hours operation if the power drops, even better bridging a partial second drop often due to lightning
    + I use a 7 Ah Li-ion bicycle battery + Marine 30A breaker (protection + on/off switch) mounted inside my grab and go box; as well have a 110 Ah AGM inside my shack
    + Fairly even draw on the PS as the battery takes the surge, also lighter gauge is possible if your PS is distant; but use 8 or 10 between battery and rig
