SmartSDR for Mac v1.4.1 now available
The new version fixes several issues and adds even more capability. There are fixes to the sound system as well.
For those of you who use MacLoggerDX as your primary logger, the SmartSDR for Mac logger can now pass saved QSOs using the WSJT-X UDP format, allowing your logs to also be copied over to MacLoggerDX if it is configured to receive from WSJT-X. This is in addition to the N1MM format already supported by SmartSDR for Mac which will soon be supported by RUMlogNG (thanks Tom (DL2RUM)). This feature makes SmartSDR for Mac an ideal on-the-fly logger with your primary logger still being used to log/track QSOs and QSLs.
I'm sure there will be an announcement shortly with all of the fixes and additions highlighted.
Thanks, Marcus, for your continued effort in making SmartSDR for Mac even more FLEXible!
Looks good! Not sure what the spot color coding is yet, or how to change it. I'm sure it will be in the updated manual.
MLDX integration is wonderful.
Audio works much better, now.
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 70 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
