MOX Control
When I activate the "MOX" button I do not have any mic audio. MOX appears to mute mic audio. Not sure if PTT is activated with MOX button. Do I have something set wrong?
Al, W1JHU
Sometimes, when I am operating remotely, I fail to notice that microphone selection pull down menu gets changed... when I operate remotely that pull down needs to be "PC". There are conditions that I know of when that setting will change to something... like "Mic". "Mic" is only for the hardwired physical mic plugged into the rig.
I don't know how you are connected to your radio Al, but if you are remote then double check that you have "PC" selected. Only then will audio flow out to your remote rig.
Did you do anything to resolve your issue?
Regards, John
When I operate remote "PC" is selected and doesn't change but the MOX button seems to mute or not connect the PC mic. When operating local (not remote) pressing the MOX button doesn't produce any audio. (MIC selected). So either way can't get any mic audio remote or local when pressing the MOX button.
Got it working!!! TNX FOR ALL YOUR HELP
Al, W1JHU
When I operate SSB I use the "Default PR781 ESSB 3_2K" MIC profile. When I switched to the "Default" MIC profile all worked OK with the MOX button. Even worked fine in remote with another PC. Don't know why it acts that way with "Default PR781 ESSB 3_2K" MIC profile. Thanks again
Al
W1JHU
CLOSED! TNX to all..
Resolved.
- 389 Community Topics
- 53 Aurora
- 971 Maestro
- 945 Genius Products
- 307 Shack Infrastructure
