Slice Master select a specific WSJT version
howardsh3t
I have more than 1 version of WSJT on my PC. When using Slice Master, it selects the version that I do not want to use for regular operation. How can I configure SM to automatically start a specific WSJT program when I change my mode to DIGU. My WSJT programs have different file names, so I would think this would be easy.
You can edit the path in the config file in AppData\Local\K1DBO\slice-master
Also useful if you install in non standard locations or want to prevent SliceMaster from controlling some apps.
Dale,
Thanks, I will give this a try.0 -
@howardsh3t This post should have been placed in the Third-Party Software category and not in SmartSDR for Windows. I have moved it to Third-Party Software so it has higher visibility
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 70 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
