SmartSDR wont start on Mac using parallels
you may have been hit with a windows update
cause this looks like a 'windows' error message.
my suggestion would be to un-install SSDR including dax & cat, reboot parallel VM, make sure windows is up todate
then reinstall SSDR., then reboot parallel vm.
i have seen similar issues running VMware-Fusion which is a windows VM
windows updates got-cha no matter where windows is runs ;-O
Paul K3SF
The strange thing Paul - this happens on a newly built OS with nothing else on it but smartsdr prior to doing any updates
While this forum being migrated i found the problem - believe it or not this was a HARDWARE issue! Talking about pulling my hair out, hard to do when you dont have any.
The machine died while working about a week ago, of course all the Apple stores were closed. I managed to find a local authorized repair center - they replaced the logic board due to a non boot issue. We came to the conclusion it was the video card. Got it back Friday and just decided to give it a go - no reinstall needed - works perfectly now
The .NET argument is mute. SmartSDR will tell you if you need a different version. I've been running SmartSDR under Parallels for more than 5 years with absolutely no problems whatsoever.
- 359 Community Topics
- 620 The Flea Market
- 8K Software
- 25 SmartSDR+
- 6.3K SmartSDR for Windows
- 415 SmartSDR for Mac
- 267 SmartSDR for iOS
- 252 SmartSDR CAT
- 188 DAX
- 377 SmartSDR API
- 9.2K Radios and Accessories
- 26 Aurora
- 221 FLEX-8000 Signature Series
- 927 Maestro
- 901 Genius Products
- 325 Tuner Genius XL
- 117 Antenna Genius
- 288 Shack Infrastructure
- 202 Networking
- 141 Contesting
- 981 Third-Party Software
