minimum signal strength for cw
roger na4rr
Just wondering what the minimum signal strength required to receive a CW signal. On FT8 I can decode signals on regular basis at -20 to -24 db. Just wondering how strong the same station would need to be if it was sending cw. Assuming 0 noise level. thanks roger
The S meter on a Flex radio typically reads S-9 as -75dbm. The reading for FT8 is actually a signal to noise ratio. Not the same thing. I have been able to copy CW signals just above the noise limit on the Flex which can be as low as -110 dbm.
Please see http://www.arrl.org/forum/topics/view/1957 for an explanation on FT8 S/N ratio.
Rick
Thanks for the reply. The reason I ask is I have a friend that does only cw he refuses to do ft8 To him "fake mode" hi. Well i was wondering how strong the ft8 signals needed to be for him to able to raise someone on cw. When I am ft8 on 6m must of the time I see no cw stations on my panadapter. I'm also talking about the db report from wsjt not the flex s- meter reading
In simplistic terms... FT8 has a bandwidth of 6.25Hz and CW has a bandwidth of 25Hz
This means that under the exact same noise conditions FT8 has a gain advantage of
10 LOG(25/6.25) = 10 LOG (4) = 6dB or 1 S unit
But if gets better for FT8 as the signal contains error correction bits and is integrated over 15 seconds--- albeit the human brain does some error correction on CW.
so in the real world, FT8 likely has a 10 to 15 dB (2-3S Unit) gain advantage over CW4 -
I can relate to the question beeing a CW op mainly. Using FT8 as a beacon for band openings, the snr numbers reported on FT8 is useful. FT8 bases the snr wrt 3 kHz BW, and I find myself often use 50 Hz filter when digging deep down into the noise. 3000/50=60 or ~18 dB. Usually I need a few dB of SNR to copy CW so I would expect a -15 dB snr on FT8 should enable me a CW QSO given the power and antennas are the same
For me a marginal CW QSO is a lot more rewardig than bagging a FT8.....
Actually FT8 bases it’s SNR reading on 2500Hz not 3000Hz
so using your 50Hz filter for CW
Then the gain advantage of FT8 is 2500/50=50 or 17dB or 3 S units
so you are doing very good copying CW when the readings on FT8 are -15dB0
- 361 Community Topics
- 620 The Flea Market
- 8.1K Software
- 43 SmartSDR+
- 6.3K SmartSDR for Windows
- 178 SmartSDR for Maestro and M models
- 416 SmartSDR for Mac
- 268 SmartSDR for iOS
- 252 SmartSDR CAT
- 188 DAX
- 378 SmartSDR API
- 9.2K Radios and Accessories
- 27 Aurora
- 224 FLEX-8000 Signature Series
- 929 Maestro
- 904 Genius Products
- 327 Tuner Genius XL
- 118 Antenna Genius
- 288 Shack Infrastructure
- 202 Networking
- 141 Contesting
- 984 Third-Party Software
