flex 6400 with acom 600s
Steve Smith
Hi all i am trying to get my flex 6400 to key my amp but no luck can anybody tell me how.
Regards GI4XFN
Regards GI4XFN
i assume you have the checkbox in the tx band settings checked for the bands you work0
Hi yes ticked tx1 then connected a phono cable to tx1 then to keyin on the amp.
Regards0 -
If you unplug the phono cable from the Flex and short the tip to sleeve, does the amp key? Are you using DDUtil and AutoDrive by chance? Dave wo2x0
I would also recommend opening a Help Desk ticket to get that process started. Dave wo2x0
You need to turn off cat/aux in the 600s - that should get you going. This is available through the 600S menu. The manual should be helpful here.0
it must have been a bad cable as i changed it now works thanks all.
gi4xfn0 -
Well, I tried to help and got myself in trouble instead.
As I said earlier you need to have cat/aux turned off for the 600s to automatically change bands.
The problem is that I tried to demonstrate this and in the process I managed to turn it back on and can't for the life of me can't remember how turn the cat/aux off in the 600S menu.
HELP!!!0 -
menu cat settings interface off
regards0 -
I am in the menu - cat/aux settings rx only
the line below that is interface off rs232 rs232 ttl
When I exit out the band bar and below that cat error, and cat aux control is green.
It was working perfectly this morning. I am doing something **** but I can't figure it out0
- 325 Community Topics
- 590 The Flea Market
- 7.8K Software
- 6.2K SmartSDR for Windows
- 394 SmartSDR for Mac
- 260 SmartSDR for iOS
- 246 SmartSDR CAT
- 178 DAX
- 368 SmartSDR API
- 9.1K Radios and Accessories
- 14 Aurora
- 153 FLEX-8000 Signature Series
- 906 Maestro
- 50 FlexControl
- 867 Genius Products
- 445 Power Genius XL Amplifier
- 308 Tuner Genius XL
- 114 Antenna Genius
- 274 Shack Infrastructure
- 194 Networking
- 135 Contesting
- 717 Peripherals & Station Integration
- 135 Amateur Radio Interests
- 939 Third-Party Software
