flex 6400 with acom 600s
Steve Smith
Hi all i am trying to get my flex 6400 to key my amp but no luck can anybody tell me how.
Regards GI4XFN
Regards GI4XFN
i assume you have the checkbox in the tx band settings checked for the bands you work0
Hi yes ticked tx1 then connected a phono cable to tx1 then to keyin on the amp.
Regards0 -
If you unplug the phono cable from the Flex and short the tip to sleeve, does the amp key? Are you using DDUtil and AutoDrive by chance? Dave wo2x0
I would also recommend opening a Help Desk ticket to get that process started. Dave wo2x0
You need to turn off cat/aux in the 600s - that should get you going. This is available through the 600S menu. The manual should be helpful here.0
it must have been a bad cable as i changed it now works thanks all.
gi4xfn0 -
Well, I tried to help and got myself in trouble instead.
As I said earlier you need to have cat/aux turned off for the 600s to automatically change bands.
The problem is that I tried to demonstrate this and in the process I managed to turn it back on and can't for the life of me can't remember how turn the cat/aux off in the 600S menu.
HELP!!!0 -
menu cat settings interface off
regards0 -
I am in the menu - cat/aux settings rx only
the line below that is interface off rs232 rs232 ttl
When I exit out the band bar and below that cat error, and cat aux control is green.
It was working perfectly this morning. I am doing something **** but I can't figure it out0
- 110 SmartSDR+
- 257 SmartSDR CAT
- 943 Maestro
