RED TX DISPLAY DOES NOT FOLLOW SELECTED SLICE
Hi,
apologies, maybe this a Colombo's egg problem, but it look unusual that  after have click over the slice not selected (red vertical line), this becomes yellow but TX (red box) doesn't follow in the new slice (now changed from red to yellow).
Where am i wrong?
thanks for help
73 i2dmi Frank
Welcome!
  • Member, Super Elmer Moderator
    edited June 2020
    Hi Frank
    You need to click on the TX on the slice flag to set it to be the TX slice.
  • Member
    edited June 2020
    Hi Dave,
    thanks for the reply.
    Yes.  At present time I do this, but  I'd  would prefer this happens automatically. When I click on second slice, also the  red TX box should be moved to that slice.
    thanks
    Frank i2dmi
  • Member ✭✭✭
    edited June 2020
    This behavior is by design. If it worked the way you are requesting, it would seriously compromise split operation. There you want the TX to stay on your transmit Slice, but be able to select and tune either slice. If it were otherwise, the result would be that ops would transmit on top of the DX half the time.
    The way it currently works is the way most of us want it. I certainly do!
    edited June 2020
    The lines show which Alice’s controls are visible in the panel on the right side of SmartSDR Dave ao2x
  • Member ✭✭✭
    edited June 2020
    You can use FRSTACK to accomplish this.
  • Member
    edited June 2020
    Thank you to all.
    Now problem is solved.
    73 Frank i2dmi
