Common Microphone and Key for Simon Browns SDR Console + Flexradio 6k
Wolf
I want to use the Microphone + Key connected to my Flexradio to feed Simon Brown's
SDR Console ? SmartSDR and SDR Console are running on the same PC. Did someone try ? Does it work with DAX ? Do I need another VAC ? How to configure it ?
Thank you, Wolf
Thank you, Wolf
Hi Wolf, I'm not sure I understood your question but I think that what you need is a audio mixer to route the audio streams from/to different sources/destination. Though, I don't think this is going to work for the Key (do you mean a morse key?).
You can give a try to Voicemeter Banana or Potato.0 -
Hi Max, Thank you for your answer. What do I want to achiev ?
(1) Lambic Paddle connected to the Flexradio - which works really well. I want to keep this functionality with all it's CW processing and at the same time I want to feed the signal into another application to key the Tx (SDR Console). The idea is to use a Virtual Audio Cable. My question: Does DAX support this or do I need to install another VAC ? And ... how to configure it ?
(2) Same story with the microphone and voice audio: Use the functionality of the Flexradio Audio Processing and feed the audio signal into SDR Console. My question again: Does it work in general and how to configure it ? Maybe someone went this path before . . . ?
Hi Wolf,
Please clarify this for me: do you have a microphone and a paddle physically connected to a 6K radio?0 -
Yes.
OK, to the best of my knowledge the answer is no, you can't do it. Maybe you can still play around with the Mike rerouting the DAX audio, but it seems to me a very complicated scenario. Much easier to use a microphone connected to the Computer and use it for both SmartSDR and SDR Console.
Using the keyer is even more complicated, a WInkeyer driving both the 6K and whatever SDR radio you are using with SDR Console is probably the way to go.0 -
Hi Max,
I meanwhile tried a Winkeyer and that works for both radios. Beside the Flexradio 6500 I just installed an ADALM Pluto SDR with the SW SDR Console. That's my rig for the QO100 satellite.
So - CW is solved. Next step is to find a solution to use my Heil Microphone for both radios.
Again - Thank you !
Hi Wolf,
I would like to run an ADALM Pluto on the same Windows 10 computer that I use for my 6300's software but I cannot get the driver package for the Pluto to install properly. Only a few of the necessary drivers actually install.
Did you have to do anything unusual to get yours running?
Hi Oliver,
Nothing special needed !
I followed the instruction in the AD Training Document and it's working fine
with USB-Interface. LAN Connect requires more effort.
My recommendation: Try to get it run first via USB and don't forget to feed 5,0 V
separately to the second USB Input.
Good luck + 73, Wolf
- 113 SmartSDR+
- 921 Genius Products
- 124 Antenna Genius
