Maestro and Dynamic Mic
Lorenzo Mendini
Hi, with my IC-7851 i use this microphone ( https://www.amazon.it/Microfono-AntLion-Audio-ModMic-bottone/dp/B00R98JVVU ) but for work it's necessary the 5V DC on pthe Mic pin.. how i can use it on my maestro? Many thanks
There is a software turn on for the Maestro mic bias. l believe under phone/cw tab.0
With Dynamic (coil and magnet) mics, adding a capacitor in series with the mic line with prevent mic damage and allow it to function.0
Not needed for the mic he specified.0
Icom (eg. IC-7851) uses electret mikes that require 5vdc to power them. Dynamic mikes, like those made by Heil, etc, do not require any phantom power or capacitors in the mike line and will work fine in the Flex with no need for biasing ( you may need to turn on the 20dB mike preamp to get adequate gain since dynamic elements are not as “hot” as electret and condenser mike elements). Bob K3AC0
- 379 Community Topics
- 636 The Flea Market
- 140 SmartSDR+
- 260 SmartSDR CAT
- 199 DAX
- 44 Aurora
- 272 FLEX-8000 Signature Series
- 956 Maestro
- 57 FlexControl
- 301 Shack Infrastructure
- 462 Remote Operation (SmartLink)
- 793 Peripherals & Station Integration
