Smartlink connected CAT and DAX but no SDR - 6600M
Rusty Jones
Smartlink was running (SSB, CW and DIG) just fine then it froze and disconnected. When it restarted CAT and DAX show the radio and connect, but Smartlink SDR hangs up (spinning) without showing a connection available. Entire laptop restarted to see if that helped.
First time running remote with Smartlink. 6600M has been fantastic so far, and It's probably my doing. Ideas?
Rusty,
Make sure that you are getting the green light in the SmartLink test at home... Once you have the correct ports, then you can check your remote connectivity, but to start, forget the remote DAX and CAT, just get SmartSDR to pass through your router to your remote SmartSDR, if you have a low speed, you may have to slow your display rate or use the "Low Connectivity " option in your remote SSDR.
Hang in there, you will find all the right options for your setup, just make one change at a time, look for improvements.. :-)
Dudley
WA5QPZ
- 391 Community Topics
- 664 The Flea Market
- 441 SmartSDR for Mac
- 206 DAX
- 59 Aurora
- 974 Maestro
- 948 Genius Products
- 348 Tuner Genius XL
- 127 Antenna Genius
- 308 Shack Infrastructure
- 216 Networking
