USB Cable by Slice A or B or ..... Not Working
Ralph Fedor
I found a post made 7 months ago reporting a problem with the USB Cable feature not working when using Slice A or B as a source. I find that I am experiencing the same problem today when attempting to drive Denkovi relay boards. If I use Active Slice as the source things work as expected. If I use Slice A or Slice B as the source in an attempt to set up an SO2R station with my 6700, it appears that this still does not work.
Or, hopefully, I'm doing something wrong that I can correct and make things work. My setup is: Enable, Active High, Slice A (or
, Band, 160-etc. I've tried two different relay boards and two different USB cables going to the boards.
Flex 6700 (just back from a repair job), Ver. 3.1.8.145
Am I doing something wrong? I really hope so. All comments and assistance appreciated.
Ralph - K0IR
Ralph - K0IR
same problem with my 6600M. I can only use slice A to drive my auto bandpass filter (Top Ten) and SteppIR box. It works fine, but doing SO2R and 2 slices, I have to "unable" the slice A output or when N1MM switches slices doing "Dueling CQ", the filters and SteppIR try to follow whatever is active. So I have to set the SteppIR box manually on the slice using that antenna.1
Hello, JIm ---
Thanks for chiming in. I find this extremely frustrating. I took apart an SO2R station with two IC-756 Pros with band decoders that had more antenna switching functionality than the 6700. Or, at least it seems that way. Again, I really hope I'm missing something.
Ralph - K0IR0 -
I posted this almost a year ago and was told it's a known bug, but haven't heard anything about it being fixed. Many of us use BPFs for SO2R and need this functionality, so I wish it would be addressed. It seems like a relatively easy fix - the problem seems to be that the USB interface doesn't get the frequency accurately and so thinks each slice is set to 0.0000 MHz.0
Ralph,
I think I am successfully doing what you need. I am driving two 8-channel relay boards that switch my Dunestar filters in SO2R. The setup for my USB cables is below.
Give me a call if you have any questions.
73, Pat KØPC
Can you relay what these relay boards are - where you get them and how you have them drive them from the 6600M
tnx0 -
I got my relay boards on Amazon but they are available from several different sources. See
https://tinyurl.com/y9bf2zds
I plug them into a USB hub that connects to the back of the Flex. Just plug them in and set them up as shown above. Supply 12V to operate the relays and you're ready to wire up your filters.0
- 383 Community Topics
- 640 The Flea Market
- 147 SmartSDR+
- 435 SmartSDR for Mac
- 262 SmartSDR CAT
- 201 DAX
- 280 FLEX-8000 Signature Series
- 958 Maestro
- 934 Genius Products
- 342 Tuner Genius XL
- 305 Shack Infrastructure
- 214 Networking
- 142 Amateur Radio Interests
