Maximum of 2 slices amongst both stations using multiflex v3.1.12
Craig Gagner
Hi, running flex 6300 with 2 win 10 pcs running ssdr v3.1.12. I am only able to have a total of 2 slices between both clients while using multiflex. For example, I can have 1 slice on each client or 2 slices on one and the other shows no pan adapter. I can destroy one of the slices and then am able to create one on the other client. I am currently networking the 6300 and two clients via a hardwired high speed ethernet switch. Thanks for your help. w7phg
The 6300 only supports two slices. Period. So if running multiflex, each client can have only 1 slice. See this page: https://www.flexradio.com/?s=Flex+6300
Thanks! I just came to that conclusion upon looking closer at the document you cite here. Much obliged, 73
- 382 Community Topics
- 638 The Flea Market
- 144 SmartSDR+
- 434 SmartSDR for Mac
- 261 SmartSDR CAT
- 200 DAX
- 958 Maestro
- 57 FlexControl
- 933 Genius Products
- 341 Tuner Genius XL
- 303 Shack Infrastructure
- 141 Amateur Radio Interests
