Leo Bodnar 10 Mhx GPSDO
AH0U
I have a Bodnar external
gps plugged into my 6700..I wait until the GPS is locked and then turn on the 6700...it goes thru its calibration and when I check the
frequency offset, it is the same as without the
gps....-2998.. I though it should be close to zero... Am I wrong or did I do something incorrectly?
Tnx Bruce
leave the GPSDO ON, then remove for 1 minute then restore the DC Voltage to the radio, then power on the Radio and SmartSDR and then run the calibration routine it should be +- 50ppm or less depending the GPSDO calibration if everything is working right.
The 6700 won't find the GPSDO SIGNAL after the radio powers up.
Bret
WX7Y
Hi Bruce, in SmartSDR on my 6400, I have to hit the start button (Settings, Radio Setup..., RX tab) to get it to calibrate. Have you tried that yet?
Len, KD0RC
Bruce, this is a feature of the Flex-6700 ;-) I had a couple of discussions with the support already. The Flex-6700 will NEVER find the external Brodnar GPSDO after a cold start. The easiest way to solve this problem is:
- power on the Flex-6700
- power off the Flex-6700 immediately
Now open a panadapter on 10MHz and the Flex-6700 will show no offset.
73 de Lars
DF1LON0
- 394 Community Topics
- 670 The Flea Market
- 177 SmartSDR+
- 453 SmartSDR for Mac
- 276 SmartSDR for iOS
- 216 DAX
- 389 SmartSDR API
- 80 Aurora
- 982 Maestro
- 954 Genius Products
- 350 Tuner Genius XL
- 130 Antenna Genius
- 312 Shack Infrastructure
- 218 Networking
- 146 Amateur Radio Interests
