IOS Transmit Issues
Hi Dwayne, My first shot when I got my 6400 had very bad audio as well. Turns out I had the mic gain way too high. When I use my Android phone or my laptop remotely, I have to adjust the mic gain differently from the FHM-3 mic plugged into the radio. Might want to check to see that you are not overdriving things as a first troubleshooting step.
Len, KD0RC
Hello. I have the same problem as well and was not able to fix it so fare. So I follow your issue, manby i can learn something from others. 73 de Kurt in3dov0
I have been struggling. Looks like IOS is also causing my radio to crash. I switched to a laptop running SDR and so far all good! Audio is excellent. I logged a support case with Flex and see what they have to say.... v3.1.12.0
i use the IOS on my iphone a lot, you can start with the default IOS setting in SDR but will need to tweak a little, people cant honestly tell the difference between the IOS app and sitting at my station. after tweaking and you think its right, be sure to save the mic profile! JMO!0
Definitely no luck but the remote crashes have put a stop to my testing until I get home - Seems like the radio crash is associated with disconnect/logging off from IOS app. I have reverted to my laptop and SmartSDR which is working perfectly from the same location.0
I have Things running on the Newest (at the time) 11" Pro Ipad. I too had many problems with the audio in the beginning with it, but the main thing is you are going to have to work with your audio and EQ settings a LOT more then I did when I had it on my older 12.9" Pro.
Seemed it was plug and play, and everyone said I sounded great, think it only had 1 mic in it, and the newer 11" has two, so that could have some to do with it, (Might be mistaken on this, as I don't use it that much) but it did take some time with playing with the output level, and with the EQ transmit settings but have it sounding pretty good now from what all say.
I found one of the best ways is to go to one of the online SDR services, and put some headphones on, and listen to yourself, that might help out some.
- 354 Community Topics
- 618 The Flea Market
- 8K Software
- 3 SmartSDR+
- 6.3K SmartSDR for Windows
- 175 SmartSDR for Maestro and M models
- 413 SmartSDR for Mac
- 267 SmartSDR for iOS
- 252 SmartSDR CAT
- 188 DAX
- 376 SmartSDR API
- 9.2K Radios and Accessories
- 24 Aurora
- 217 FLEX-8000 Signature Series
- 923 Maestro
- 861 FLEX Series (Legacy) Radios
- 897 Genius Products
- 325 Tuner Genius XL
- 116 Antenna Genius
- 286 Shack Infrastructure
- 201 Networking
- 140 Contesting
- 759 Peripherals & Station Integration
- 979 Third-Party Software
