PGXL Bypass Connect Dialog and just connect?
Wayne Westfield
Is there a way to start the PGXL Utility that bypasses the connect dialog and connects to the AMP? Maybe a command line. I am trying to script the start up of the applications I use to operate.
Kind regards,
Wayne
KG5MGN
Kind regards,
Wayne
KG5MGN
You could use AutoHotKey and write a hotkey macro to simulate clicking a mouse on the required button. It works really slick and even comes with a utility to read the mouse position to set it up. You can generate the necessary hotkey with a SendKeys command in your script.
I have been using it for quite a while and really like it.
Please post exactly your script if you find one that works
Tnx0 -
+1 for AutoHotkey, Craig. I use it as my main scripting tool. I've automated lots of tasks on my Windows 10 PC, including SSDR, previously. I had it set up to start DAX and CAT and shut them when exiting SSDR (before they implemented that into SSDR).0
Here is a script that I wrote for AutoHotKey to activate buttons on the KPA1500 Remote program. You could modify this with the correct window title and button position to do what you want. Note: use the WindowSpy utility that comes with AutoHotKey to find the position of the button in the PGXL window.
#SingleInstance force
^+c:: ;Connect KPA1500 Remote Ctrl-Shift-C
prev:=WinActive("A")
WinActivate, KPA1500 Remote
Click, 60, 40 ;Click mouse on Local Connect
Sleep, 500 ;Wait a half-second
Click, 210, 293 ;Click mouse on Connect
if prev
WinActivate, ahk_id %prev%
return
^+t:: ;Click "Tune" button on KPA1500 Remote Ctrl-Shift-T
Click, 100, 70 ;Click "Standby"
Sleep, 500
Click, 290, 325 ;Click "Tune" at postion 290 325
if prev
return
^+u:: ;Untune: Click "Standby" button on KPA1500 Remote Ctrl-Shift-U
if prev
return
^+k:: ;Exit this script Ctrl-Shift-K
ExitApp
return
- 650 The Flea Market
- 152 SmartSDR+
- 49 Aurora
- 964 Maestro
- 937 Genius Products
- 343 Tuner Genius XL
