Operating a flex owned by an operator in a foreign country
Martin Boroff
Which call sign do you use when operating a remote Flex radio using SmartSDR and the radio is owned and located in a foreign country? Would you have to apply for a license in the foreign country? Would you use the call sign of the station owner?
Their call sign / your callsign0
It completely depends on the rules of the foreign country. Some countries have reciprocal agreements that allow you to operate under your callsign/portable whatever (still need to be sure remote operation is OK). Make sure that you find out for sure what the applicable ruleset is for wherever you plan on remotely operating. Going outside their rules will likely cause more problems for the host operator than for you.
Len, KD0RC
I have done it both ways many times.
If the local control operator is in "Control" then the same 3rd party rules apply as the rules for Phone Patches http://www.arrl.org/phone-patch-guidelines .
If there is no "control" operator. then it depends on the reciprocal licensing agreements between countries...
That said, if you are dealing with a CEPT (European Conference of Postal & Telecommunications Administrations) country and the USA you definitely can do it and I have done it many times
http://www.arrl.org/cept
BTW... don't get too bothered by the rules police.. most countries do not care that much about ham radio these days... so enforcement of the rules can be very lax EXCEPT when you do something really obviously against the local rules like "Politics, Profanity, Interference. or beating the locals in a contest, hi Hi,0 -
Remoting from The south of France I use F6/KY6LA1
For instance in Germany the rule would be dl9ndw/W0XYZ . if you operate a station which is owned and at the location of another operator, you prepend his callsign . You cannot use a CEPT prepend permanently, just a few weeks and then you need a local license. The duration depends on local rules. I think in a near future, newer rules will usually cover remote operation which in many countries is still a "grey zone".
- 378 Community Topics
- 118 SmartSDR+
- 192 DAX
- 38 Aurora
- 947 Maestro
- 924 Genius Products
