idea cluster spot
IK8HCG
IK8HCG Member ✭✭
edited May 2020 in New Ideas
when will flex radio or slice master give the possibility to send spots on clusters without having another program running?
at the moment there is only the possibility to delete the spots viewed on the panadapter
0 votes
In Review · Last Updated
  • Tim - W4TME
    edited May 2020
    The program where you enter a call sign, usually a logger, which also has the slice frequency has to be the one to send the spot. The radio itself has no knowledge of the station you are working.
  • IK8HCG
    IK8HCG Member ✭✭
    edited May 2020
    Tnx Tim for your reply. But with no logger sw running you cannot send anything thru ssdr.
  • Tim - W4TME
    edited May 2020
    With an M model radio or a Maestro, there is no way to enter spot data to be sent.  There is no keyboard and using the touch screen would be very clumsy to use, slowing down the workflow (operation) of the radio.
  • IK8HCG
    IK8HCG Member ✭✭
    edited May 2020
    Yes i know, u right. But i m talking about with simple 6400 and during a swl contest should be very interested in to enter a spot data with ssdr. But was a simplea idea, that's ok
