My 6400M has issues, will not TX using my mic, tune's ok SWR on Tune up 1.15 at 10W. Max pwr 100 jus
budr@rjrpiping.com
6400M will not TX
If you mean that the PTT on the mike does not make the radio TX? Can you go into more detail? what mic and what setttings?0
What version was you running before 3.18?
power down the radio unplug DC power wait about 5-10 minutes then power the radio up and see if it is still having issues, if it is then try a HARD RESET.
This will do a Soft Reset by removing DC Power and then a Hard reset by holding the Power button until the button turns white I think.
This will erase your profiles so you may want to export them before doing the Hard reset.
Bret
Bill, not sure I believe it was 3.17... I am using Heil Pro6 head set as my default and did the Hard Reset and put all the value's back (TX settings and Mic default). I even tried the hand mic but got the same result. Funny the TUNE works fine 10W low SWR, so it must be on a separate TX than the PTT.0
Thanks for the reply, did all though things, shut down for 15 minutes, then a Hard Reset, entered all the value's back. even tried an older version but no change...
Bud N4RJR
I still don't fully understand what is wrong? is it not transmitting? PTT does not work. How are you keying the radio? I use Vox for my headset. Are you using the correct cable for the Pro6 headset? to the flex?0
Nor do I.. best bet is open a ticket and have someone with flex work with you. we can go round and round out here.. get a ticket open and get qrv.0
Bill, the only TX I can do is TUNE, it will transmit when I tune up with 10 Watts. After that I try to TX with 100W and get nothing. I switched mic's and nothing! I am using the same cables I have been using for the last 3 years.0
Did you check the TX band settings in the drop down chart?
And did you start you help ticket as you should have?0 -
Did you check the Power slider? I had a similar situation. I then slid the Tune power slider up to 100 watts and it transmitted 100 watts on Tune. Then noticed the Power slider was on Zero watts. For some reason it had defaulted to zero. I assume your PTT is lighting the Red LED on the radio.0
Have you tried clicking on the MOX button in SmartSDR? If the MOX button still works, it could point to a problem with the PTT switch, cable or jack. If not, then it would indicate a configuration problem of some sort.
Len, KD0RC
I had the same issue recently with my 6400M and the stock Flex hand mic. All of a sudden during a QSO the rig would not go into TX. The mico switch in the microphone for PTT broke, It is just a very cheap tiny plastic switch. I replaced it with one from a Motorola mic. It was not a exact fit but it does work for now.
- 389 Community Topics
- 53 Aurora
- 971 Maestro
- 945 Genius Products
- 307 Shack Infrastructure
