CW only keys with breakin enabled (6600)
Ray
Hi all,
Just updated to 3.1.11 about a week ago and have been mostly on FT8 since, not sure if this is a cause....
In CW mode, the paddle keys the 6600 into transmitting CW only with BREAKIN enabled. When not enabled, it does key with MOX clicked (and keying the paddle). Using PTT on a mic (this activates MOX) also allows keying with the paddle.
Dev Mgr (updated Win 8.1) shows the "P"-square-defined COM 8/108 ports working properly.
I checked the new manual; don't have a clue...
Any thoughts?
73, Ray N6HE
Any thoughts?
73, Ray N6HE
That's the way it has always worked. It doesn't mean that you have to use QSK, because you can crank in a delay to hold the rig in transmit between CW elements, or you can set the delay to 0 for full QSK. It is nice because you can key the radio with only the sidetone to set keyer speed or help to zero beat by matching your sidetone to the received pitch.
Must not have been clear. Radio does not key unless breakin is selected. Without breakin selected, I'd expect CW keying with the 6600 staying in TX mode until the dropout happens per the delay setting but it doesn't; doesn't key at all.0
Not so. With an external key or keyer, the radio will NOT key unless "Breakin" is enabled. With the internal CWX keyer, it ignores the "Breakin" button and keys regardless. (Unless that was changed in v.3.1.11.)
Think of the "Breakin" button as the CW equivalent to the "VOX" button on SSB.
OK, OK, I (I think) stand corrected. I moved up from SSDR 1.something to 3.1.8, then quickly to 3.1.11; this "breakin" function seems to have changed completely. So now "break-in" now includes "semi-break-in" - and for true QSK break-in you set the delay to 0, as you said. Odd (to me), but I get it now. Thanks!!!!
Ray0 -
You are welcome, Ray! Glad you have it working now. I do a lot of CW and find that I really like the way it works.
- 113 SmartSDR+
- 921 Genius Products
- 124 Antenna Genius
