Power Up hangs after v3.1.11 upgrade
Thomas NE7X
Thomas NE7X Member ✭✭
edited June 2020 in FLEX-6000 Signature Series
I performed the v3.1.11 upgrade and now my 6400M no longer boots. It stops at the FLEX-6400M blue logo screen. I power cycle and reboot again and again and again. I can not get the radio to come back upimage
  • Pat N6PAT
    Pat N6PAT Member ✭✭
    edited May 2020
    I don't own a 6400M but perhaps a factory reset would solve the problem
  • Robert Lonn
    Robert Lonn Member ✭✭
    edited May 2020
    And shut it down, remove DC power after 1 Minute, UNPLUG the DC power cable,,  leave off for 5 minutes, then re-power the radio!!
  • WX7Y
    WX7Y Member ✭✭✭✭
    edited June 2020
    if the above doesn't work then I would DO a trouble ticket!
    Pretty sure my F6600M lost the SDCARD again with this updated because it is doing the same as you described and the same as 1 year ago when I had to replace the SDCARD.
    There have been several others on here that have the same issues so I know Flex will sort this out for us, Luckley the Flex6600M is my backup radio to my FLEX 6700.
    One of the Fix's in this firmware was to fix the SDCARD from getting corrupted if I remember right,
     Just guessing but Maybe the reason these issues come up with THIS update may be if the SDCARD in the radio has already been corrupted and it dumps the OS and won't boot the radio any longer if the checksum of the OS is wrong or something.
    Probably wrong but that's my guess
    73's
    Bret
  • bahillen
    bahillen Member ✭✭✭
    edited May 2020
    You have to unplug the radio from the power supply. to get a clean reboot. Mine drove me crazy until I did that. Plug back in a minute or two.
    Bill
  • W9EN
    W9EN Member ✭✭
    edited May 2020
    Hi Tom, The release notes specifically called out the “cold boot” process so I imagine there are some volatile memory contents that needed to be wiped out to be compatible with the new version. Even after removing DC power for 30 seconds, that first boot took a lot longer than normal. John W9EN
  • Thomas NE7X
    edited May 2020
    Cold boot over night, powered up in morning, booted OK. Keeping my fingers crossed the issue is resolved.
    NE7X...
  • W9EN
    W9EN Member ✭✭
    edited May 2020
    Cold Boot followed by cold **** works every time!
