Flex 6400M VFOs A and B
Scott Oakland
Scott Oakland Member ✭✭
I have a Flex 6400M and have had it for about a year or so. I have always used it using VFO A on one frequency at a time, on 20M. What I am looking to do seems quite simple but cannot figure it out. I want to be able to put a 6 Meter frequency on VFO B, while retaining the 20 meter frequency on VFO A. When I attempt to do it it removes the present 20 Meter frequency on VFO A and replaces it with 6 meters. What am I doing wrong? Thanks in advance.
  • Andy W3LI
    Andy W3LI Member ✭✭
    edited May 2020
    Scott, I am doing the same thing. If you send me your email address I will send you the information. you will need to purchase a Duplexer.
    Andy... W3LI        Send to xtraham58@hotmail.com.
  • Scott Oakland
    edited May 2020
    Okay I emailed you, thanks :)
  • W9EN
    W9EN Member ✭✭
    edited May 2020
    Hi Scott. No “duplexer” should be required. Just press the ^ symbol at the bottom of the waterfall to activate VFO B. The press the frequency displayed on the B side and select 6m. I’ve included a picture of my display. 73, John W9EN image
  • W9EN
    W9EN Member ✭✭
    edited May 2020
    OK, never mind I see the issue now.  It changes the ANT port.
    Sorry for my added confusion.  Yes, an HF/VHF Diplexer will allow you to connect both antennas to ANT1.
    John W9EN
  • Andy W3LI
    Andy W3LI Member ✭✭
    edited May 2020
    Thanks Joun, I have been playing with this for several months trying to find a work around. Did not think that I missed anything.
    Andy
  • Scott Oakland
    edited May 2020
    I just tried what you suggested and it appears to work though. I have 6 Meters in a separate slice on a separate antenna which is what I was looking for. Or am I missing something?
  • Scott Oakland
    edited May 2020
    I just tried it and it won't give me ANT 2 for slice B (6 meters) and ANT 1 for Slice A (HF) at the same time.
  • Andy W3LI
    Andy W3LI Member ✭✭
    edited May 2020
    That is why the duplexer and the MFJ band switch as per the diagram I sent you. Do what ever.
    Andy.
  • Scott Oakland
    edited May 2020
    YEs I got your email. I just saw John's comment and was curious. Thanks!
  • Scott Oakland
    edited May 2020
    I appreciate the comprehensive email and help! Once I get up and running on 6M I will get a duplexer.
