Problem with my logger32 and my flex 6600 CAT control.
MIKE
MIKE Member
hi guys
i have the 6600 for 2 weeks now and i am really impressed with the performance compared to my previous FT9000D yaesu.
however i tried to connect my L32 with the CAT features the last 2 days and i noticed that
1.if i am on v2.4.9 smartsdr and i change to another band the L32 goes to the right band but the mode is always on SSB
2.if i am on L32  and i see a spot in the L32 cluster the smartsdr switch to the correct band but doesn't switch to the correct mode ( it is always stuck to the previous mode)
i have been to SETUP /RADIO 1 configuration  and all looks okay to me
see attach pic
any ideas how to solve this problem
thank you in advance
mike  SV9CVY
  • MIKE
    MIKE Member
    edited October 2018
    problem solved
    THANK YOU LOU N2TU for your help
    i had to correct in the  "edit Bands & Modes" of the L32  all the dig. modes like FT8,Psk etc in "radio mode"  DIGU   and in cw with CWL
    thank you Lou
    73 sv9cvy mike
  • EC5K Vic
    EC5K Vic Member
    edited May 2020
     Gracias Mike y Lou, este era mi problema tambien, hay que poner CWL en vez de CW.
    Saludos
    EC5K Vic
