3.1.11 Order in Maestro
The new Release of SSDR 3.1.11 is now in the Maestro as Tim mentioned a few min ago.
There is an issue in the way its recorded in the Maestro is now out of order v3.1.8 is at the top and 2 below this is the NEW version v3.1.11 why would this be???
Anyone else have this issue?
Ian
Ian
I saw that too. but it loads fine so no problem.
Version numbers are actually strings, not actual numbers. When a string is sorted the "8" comes before two "1'"s.0
Thanks Tim
You're very welcome. 73.0
Tim:
Is this update Windows software only or is it a firmware update to the radio? I ask because of the cold boot recommendation in the update process documentation.
thanks0 -
It's a firmware update; the hint is in the release notes showing a fix to SD card corruption.
73's
Tim0 -
There is always a radio firmware update included with the SmartSDR client software (SmartSDR for Windows, Maestro, and SmartSDR for the M model radios) with every software release0
Ok I will be sure to do the cold boot.
thanks Tim and k3Tim.0 -
TNX Tim !0
Tim
In the hopes you read this THANKS for taking care of the versions in Maestro all reads correct with the version sequence.
Ian
- 383 Community Topics
- 640 The Flea Market
- 147 SmartSDR+
- 435 SmartSDR for Mac
- 262 SmartSDR CAT
- 201 DAX
- 958 Maestro
- 934 Genius Products
- 342 Tuner Genius XL
- 304 Shack Infrastructure
- 142 Amateur Radio Interests
