Flex 6000 and Log4OM V2 Dual VFO Display
Brad Adams (N4PYI)
I am running a Flex 6300 and I use Log4OM V2. I am interfaced to hte SmartSDR CAT with OmniRig V1.19 for CAT control with Log4OM V2. In Log4OM there is a dual VFO frequency display, but I have not been able to get both VFOs to display. Only the slice that the CAT port is tied to, such as Slice A. I am assuming there in no way to show both via the omnirig interface. Anyone had any experience with this?
Brad, N4PYI
Brad, N4PYI
I would too... I tried setting up OmniRig rig 2 with it’s own com port. When a b slice is running I can toggle between the the two slices but it only appears on one display. Would be nice to see display b with the slice b frequency without having to toggle between them, only should need to toggle for logging purposes. Maybe some one has some answers. I know that some one had it running on V1 Log4OM.0
As Pat says VFO A and VFO B will not display at the same time, you have to toggle between them. But if your saying you can not get VFO B to work at all, you need to create a second cat port in smartsdr cat and asign it to slice B and create a second rig in omnirig with that com port.
- 354 Community Topics
- 619 The Flea Market
- 8K Software
- 4 SmartSDR+
- 6.3K SmartSDR for Windows
- 414 SmartSDR for Mac
- 267 SmartSDR for iOS
- 252 SmartSDR CAT
- 188 DAX
- 377 SmartSDR API
- 9.2K Radios and Accessories
- 26 Aurora
- 220 FLEX-8000 Signature Series
- 927 Maestro
- 898 Genius Products
- 457 Power Genius XL Amplifier
- 325 Tuner Genius XL
- 116 Antenna Genius
- 287 Shack Infrastructure
- 202 Networking
- 141 Contesting
- 979 Third-Party Software
