Minor CW wish list item
KD0RC
edited April 2020 in New Ideas
I know this is a really small thing, but I think it is probably pretty easy to implement.  When I turn Breakin off, the paddles and straight key behave as expected - sidetone is keyed, but radio does not transmit.  So far so good.  However, if I use CWX to send a memory, or send using the keyboard, it keys the transmitter regardless of the Breakin setting.  I know that I can set the RF power to zero, but I find it annoying that Breakin does not also control CWX.  If this could be changed, I would sure appreciate it!
Len, KD0RC
2 votes
Open for Comments · Last Updated
  • Craig_KØCF
    Craig_KØCF Member ✭✭✭
    edited April 2020
    I agree 100%. I complained about this a long, long time ago, but nothing has happened. It absolutely should not transmit if Breakin is turned off. Period.
  • Paul G4AFU
    Paul G4AFU Member ✭✭
    edited April 2020
    Yes, some requests for CWX additions were made 5 years ago and were "under consideration".
    I'm thinking of beacon mode, pause for auto CQ's etc.
  • Joe N3HEE
    Joe N3HEE Member ✭✭
    edited April 2020
    With the FRLogger CW panel you can create very powerful macros such as beacon mode, adding delay or pause between CQ's, etc.  Check it out !
    http://ws7m.net/index.php/logger
  • Paul G4AFU
    edited April 2020
    I'm open minded Joe....I'll take a look at FRLogger.
  • Joe N3HEE
    Joe N3HEE Member ✭✭
    edited April 2020
    I’d be happy to help you create some CW macros Paul. Give me a shout if you need me. -Joe
