Minor CW wish list item
I know this is a really small thing, but I think it is probably pretty easy to implement. When I turn Breakin off, the paddles and straight key behave as expected - sidetone is keyed, but radio does not transmit. So far so good. However, if I use CWX to send a memory, or send using the keyboard, it keys the transmitter regardless of the Breakin setting. I know that I can set the RF power to zero, but I find it annoying that Breakin does not also control CWX. If this could be changed, I would sure appreciate it!
Len, KD0RC
Len, KD0RC
2
I agree 100%. I complained about this a long, long time ago, but nothing has happened. It absolutely should not transmit if Breakin is turned off. Period.
Yes, some requests for CWX additions were made 5 years ago and were "under consideration".
I'm thinking of beacon mode, pause for auto CQ's etc.
With the FRLogger CW panel you can create very powerful macros such as beacon mode, adding delay or pause between CQ's, etc. Check it out !
http://ws7m.net/index.php/logger
I'm open minded Joe....I'll take a look at FRLogger.0
I’d be happy to help you create some CW macros Paul. Give me a shout if you need me. -Joe0
- 378 Community Topics
- 118 SmartSDR+
- 193 DAX
- 38 Aurora
- 257 FLEX-8000 Signature Series
- 947 Maestro
- 924 Genius Products
