Transmit frequency off using MRP40 CW program
Bob - WD8KND
Is anyone using the CW program MRP40 with a Flex 6000 series? I finally got it working, but it transmits a KC or 2 off the receive frequency. Any ideas of why it is doing this, or solutions would be appreciated.
As i said in the other post, use RIT to offset. It works fine.
I tried that, and it didn't work. I'll try again. Thanks.0
check to see if the flex software or the cw program may have 'xit' turned on, or set in a split mode, maybe
I figured it out. I set the XIT to -200 for USB, and 200 for LSB. I don't know why that number, but I experimented and it works perfectly. Thanks for the remarks.
Why are you not using both USB. Or better why not cw mode0
I downloaded MRP40 tonight since there is a trial version. It was easy to configure it to use the Flex Winkeyer emulation. Just select Winkeyer as your mode of CW transmission and put in the COM port of your Winkeyer as defined in the SmartSDR CAT settings. Then you can run the rig in CW mode, and the dial reads correctly and you are transmitting and receiving on the same frequency. The TX speed is set by the Speed slider in SmartSDR.
Doug K4DSP
Doug, I'm not familiar with that, but I'll look into it.
Bob0
- 342 Community Topics
- 612 The Flea Market
- 7.9K Software
- 6.3K SmartSDR for Windows
- 407 SmartSDR for Mac
- 266 SmartSDR for iOS
- 249 SmartSDR CAT
- 186 DAX
- 374 SmartSDR API
- 9.2K Radios and Accessories
- 20 Aurora
- 199 FLEX-8000 Signature Series
- 919 Maestro
- 890 Genius Products
- 452 Power Genius XL Amplifier
- 322 Tuner Genius XL
- 116 Antenna Genius
- 283 Shack Infrastructure
- 199 Networking
- 137 Contesting
- 748 Peripherals & Station Integration
- 138 Amateur Radio Interests
- 971 Third-Party Software
