CAT command that will enable/disable DAX
Adde Tjernberg
Hello!
Does anyone know the CAT command that will enable/disable DAX?
73 de Adde, SM0SHG
73 de Adde, SM0SHG
other than tapping on the icon in smartsdr, putting the radio is none sound card mode would do it automatically. try changing to a ssb mode. are you not using smartsdr?0
Not sure I understand your answer... or if you understood my question?!0
are you using smart sdr??0
Well, yes...0
I’ve been looking for this too so I can use dvk remotely from my contest logger. Sadly I’ve not been able to find anything. Dave: Whilst Dax is often used for “soundcard modes” my example shows that it has a valuable use in regular Ssb too. This works great when you are next to the rig and your normal voice goes through the mic port. 73 Steve M0bpq0
I've been looking for this as well but couldn't find a command to enable/disable DAX.
As a workaround, i created some profiles with DAX enabled or DAX disabled and then loading the required profile via the CAT command. I'm using mic profiles, but i guess you could use global profiles as well.0 -
ZZDX0; = DAX OFF
ZZDX1; = DAX ON
THANK YOU!0
Mike, where I can find whole list of the comands?! As in n1mm can get working but if making full script getting on but off no. Maybe need put time delay between commands as if both executed at the same time dosent work. What cat time off command can be used. This is for voicekeyer then using remotely. Tnx. Kes-m0pkz0
- 631 The Flea Market
- 123 SmartSDR+
- 195 DAX
- 39 Aurora
- 950 Maestro
- 925 Genius Products
- 337 Tuner Genius XL
