Flex 6600 with SPE 1.5K enhancement
Tom Worthington
I have a Flex 6600M, SPE 1.5k and two antenna systems. I use a Steppir for 6-40m and a pair of crossed dipoles for 60,80 and 160m. The problem was I could not listen on the two antenna systems simultaneously and still be able to transmit with the amplifier on either antenna. Ant1 from the Flex is connected to In1 of the SPE. The Steppir is connected to Out1 of the SPE. I use the Tx1 line on the Flex to key the amplifier and use both hardware ALC and RS232 power control between the SPE and the Flex.
I added a high power relay from W6PQL that switches the dipole antennas either to the Ant2 connection on the Flex (NC) or to the Out2 connection on the SPE (NO). The relay is controlled by the Flex Tx2 line. On all bands except 60 the Flex transmits on Ant1 but receives 60/80/160 on Ant2. On 80/160 asserting both Tx1 and Tx2 switches the antennas and keys the amp. On 60m I receive and transmit using Ant2 of the Flex because I can only run 100 W and the internal tuner on the Flex handles the antenna mismatch better.
73 and Aloha, Tom, NH6Y
Sounds like a great configuration. Just to clarify, is the 60/80/160 dipole a fan dipole? Also, what switching do you use between the "crossed" dipoles?0
Just a pair of dipoles at more or less 90 degrees with a common feed point. They are each tuned for the CW/Digital end of the bands. It tunes on 60m with some difficulty but I only use if for inter-island communications so it doesn't need to be very efficient.
There are a couple of advantages, first I can listen (on any band) on the dipoles while Rx and Tx on the Steppir taking full advantage of having two SCU's and if I turn the power off to the amp it defaults to being able to operate on either antenna directly from the Flex.
Before this I had to manually switch the dipole system from the SPE output to the Flex Ant2 connection.0
- 398 Community Topics
- 678 The Flea Market
- 191 SmartSDR+
- 392 SmartSDR API
- 91 Aurora
- 988 Maestro
- 962 Genius Products
- 352 Tuner Genius XL
- 317 Shack Infrastructure
- 222 Networking
