RTS output to key sequencer
AH0U
I am using WSJT with my 6700 and need a PTT command to key a sequencer.. I set up a PTT com port in CAT and set WSJT rig to HRD and PTT to RTS and com port to the one I set up but when I try the PTT it keys the rig and not the sequencer... any help in how to set this???
Have you tried setting up Tx control in your Setup, Tx band settings for the appropriate profile? You can engage one of your RCA slots for TX1 etc, which will give you a Tx low when your rig switches to transmit. Connect your sequencer to the chosen RCA port and you should be good to go.
That would be backwards...I need the sequencer to key the radio not the radio to key the sequencer.... tnx fer the response but I'll have to keep looking0
- 389 Community Topics
- 53 Aurora
- 971 Maestro
- 945 Genius Products
- 307 Shack Infrastructure
